Launches the Prediction Profiler. For nominal or ordinal responses, each response level is represented by a separate row in the Prediction Profiler. For details about the options in the red triangle menu, see Prediction Profiler Options in the Profilers book.
Launches the Prediction Profiler. Similar to the Profiler option, except that all categorical probabilities are combined into a single profiler row. Available only for nominal or ordinal responses. For details about the options in the red triangle menu, see Prediction Profiler Options in the Profilers book
Launches the Contour Profiler. This is available only when the model contains more than one continuous factor. For details about the options in the red triangle menu, see Contour Profiler Platform Options in the Profilers book
Launches the Surface Profiler. This is available only when the model contains more than one continuous factor. For details about the options in the red triangle menu, see Surface Plot Platform Options in the Profilers book.
Creates an ROC curve. Available only for nominal or ordinal responses. For details about ROC Curves, see ROC Curve in Partition Models.
Creates a lift curve. Available only for nominal or ordinal responses. For details about Lift Curves, see Lift Curve in Partition Models.
Creates prediction formulas and saves them as formula column scripts in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See the Formula Depot topic.
Creates a new column in the data table that identifies which rows were used in the training and validation sets. This option is not available when a Validation column is specified on the Neural launch window. See The Neural Launch Window.
Publish Prediction Formula
Save Transformed Covariates
