Parameter Estimates for Centered and Scaled Predictors
The p-value for the Wald test.
The lower bound for a 95% confidence interval for the parameter. You can change the α level in the Fit Model window by selecting Set Alpha Level from the red triangle menu.
The upper bound for a 95% confidence interval for the parameter. You can change the α level in the Fit Model window by selecting Set Alpha Level from the red triangle menu.
Help created on 10/11/2018
