Parameter Estimates for Original Predictors
The p-value for the Wald test.
The lower bound for a 95% confidence interval for the parameter. You can change the α level in the Fit Model window by selecting Set Alpha Level from the red triangle menu.
The upper bound for a 95% confidence interval for the parameter. You can change the α level in the Fit Model window by selecting Set Alpha Level from the red triangle menu.
The VIF for the ith term, xi, is calculated as follows:
where Ri 2 is the RSquare for the regression of xi as a function of the other explanatory variables.
Help created on 10/11/2018
