Figure 3.34 List Check Property Added to a Compressed Character Column
Figure 3.35 Column Info Window Showing Numeric Column before and after Compression
To compress columns, select one or more columns and select Cols > Utilities > Compress Selected Columns. (Select all columns if you do not know which columns can be compressed.)
Help created on 7/12/2018
