Shows a list of color themes that affect continuous variables in color maps. The default color theme is Blue to Gray to Red (corresponding to small values to middle values to large values). Use White to Black to create a gray-scale plot.
Note: To see custom colors, you must first create them. Select File > Preferences > Graphs. In the Color Themes area, click the type of color theme that you want to create, click New, and then change the colors. See Create Color Themes in the Using JMP for details about creating custom color themes.
Use the Graph Type option to change the appearance of the graph.
Figure 9.5 Graph Types
Help created on 7/12/2018
