Publication date: 11/29/2021
Project Bookmarks
In a JMP project, you can create a shortcut to a file or folder in the Bookmarks tool pane. You can also organize your bookmarked files and folders by creating a bookmark group.
Tip: To hide or show the Bookmarks tool pane, select Project > Show Bookmarks. To specify which tool panes appear by default when you create a project, select File > Preferences > Projects and choose the initial tool panes.
Bookmark an open file in the project
• Right-click a tab and select Bookmark.
• To bookmark all open files, right-click a tab and select Bookmark All.
Bookmark a file or folder on your computer
Drag a file or folder from your computer into the Bookmarks tool pane, or click the Bookmarks red triangle menu and select Add Files or Add Folder.
Note: If you add or remove files from a bookmarked folder on your computer, the folder contents automatically update in the project.
Open a bookmarked file
In the Bookmarks tool pane, double-click a file.
Remove a bookmark
In the Bookmarks tool pane, right-click a file and select Remove Bookmark.
Create a bookmark group
1. Click the Bookmarks red triangle menu and select New Group.
2. Name the group and click OK.
3. Drag new or existing bookmarks into the group, or in the Bookmarks tool pane, right-click the group and select Add Files or Add Folder.
