Predictive and Specialized Modeling > Response Screening > The Response Screening Personality in Fit Model
Publication date: 03/03/2025
If you are interested in univariate tests against linear model effects, you can fit the Response Screening personality in the Fit Model platform. The report and tables produced test all responses against all model effects. An example using the Response Screening personality is given in Example of the Response Screening Personality.
• Launch Response Screening in Fit Model
• The Fit Response Screening Report
• Fit Response Screening Options
