Fitting Linear Models > Causal Treatment Models > Causal Treatment Report Window
Publication date: 07/15/2025
Image shown hereCausal Treatment Report Window
In the Fit Model launch window, when you select the Causal Treatment personality and click Run, the Causal Treatment report that appears contains a Model Launch control panel for fitting additional models. See Model Launch Control Panel.
The Model 1 report is shown after the initial model is launched through the Fit Model launch window. When the Model Launch control panel is used, additional Model reports are added sequentially. See Model Reports.
