Publication date: 01/13/2026
Delete Column Properties
To delete the same properties across multiple columns
1. Select the columns that contain the attributes or properties that you want to delete.
2. Select Cols > Standardize Attributes.
3. Under Delete Properties, click Column Properties and select the properties that you want to delete.
4. Click OK.
Note: Make sure that you click OK and not Remove. Clicking Remove simply removes the property from the list but does not delete it.
