Quality and Process Methods > Legacy Control Charts > Launch a Legacy Control Chart Platform
Publication date: 01/13/2026
When you launch a legacy control chart platform by selecting Analyze > Quality And Process > Legacy Control Charts, a launch window similar to Figure 13.2 appears. The specific controls vary depending on which type of chart you select. Initially, the window shows the following types of information:
• Process Information for measurement variable selection
• Chart type information (for more information, see Overview of Legacy Control Charts)
• Limits Specifications
• Specified Statistics
Figure 13.2 XBar Control Chart Launch Window
For more information about the options in the Select Columns red triangle menu, see “Column Filter Menu” in Using JMP.
