Publication date: 01/13/2026
Standardize Column Attributes
By default, the items within the Standardize Attributes panel are dimmed. To access an item, click the Attributes button and select the items to be duplicated across columns.
Note: The Input Format item is applicable for the Date, Time, and Duration formats only.
To change the values of any of the attributes, use the menus in the Standardize Attributes panel.
