DRAFT help
Using JMP > JMP Reports
Publication date: 01/13/2026
JMP Reports
Navigate and Customize Report Windows
Most JMP platforms present the results of your analyses in a report window. The report window consists of graphs and statistical reports that are often linked to the data table. When you select data in the graph or report, the data are highlighted in the data table. Figure 9.1 shows an example of selected data in a report window and in a data table.
This chapter describes how to customize the colors, lines, data points, and other graphical elements in a report window.
Figure 9.1 Example of a JMP Report Window and Data TableĀ
Contents
Navigate JMP Reports
Use the Hand Tool
Display Options for JMP Reports
Show and Hide Parts of a JMP Report
Combine Several JMP Reports
Rename Report Titles
Increase Font Sizes in Reports
Resize a Report Window
Red Triangle Options in JMP Reports
Local Data Filters in JMP Reports
Redo Menus in JMP Reports
Save Script Menus in JMP Reports
The Data Filter
Types of Data Filter Columns
Filtering Modes
The Data Filter Panel
Red Triangle Options for the Data Filter
Animation in Data Filters
Red Triangle Options for Variables in Data Filters
Filter Views
Reformat Tables in JMP Reports
Change Display Box Properties in a JMP Report
Change a Table in a JMP Report into a Matrix
Use Conditional Formatting in JMP Reports
Select Points in JMP Graphs
Select Rows in JMP Graphs
Select a Rectangular Area of Points in a JMP Graph
Select an Irregularly Shaped Area of Points in a JMP Graph
Use Markers in JMP Graphs
Change the Shape of Markers
Change the Color of Markers
Change the Size of Markers
Work with Crowded Markers
Add Outlines Around Markers
Change the Selection Mode of Markers
Specify the Transparency of Markers
Exclude and Hide Markers
Use Images as Markers
Change the Shape or Color of Markers Based On Values
Change the Appearance of JMP Graphs
Resize Graphs
Zoom In on Graphs
Change Line Widths in Graphs
Change the Background Color in Graphs
Change the Color of Histogram Bars
Display Coordinates and Temporary Reference Lines in Graphs
Scroll and Scale Axes in Graphs
Customize Axes and Axis Labels in Graphs
Change the Order of Values in Reports
Change the Pattern and Format of Selected Objects in Graphs
Add a Graph to a Data Table
Customize Markers, Lines, Text, and More in Graphs
Add Images to a JMP Graph or Report
Paste a Background Image into a JMP Graph
Paste an Image at the End of a JMP Report
Drag and Drop an Image into a JMP Graph
Add Geographical Images and Boundaries to JMP Graphs
Extract Data from an Image
Add Annotations and Shapes to JMP Reports and Graphs
Add Annotations to JMP Reports or Graphs
Add Shapes to JMP Reports
Customize Hover Labels in JMP Graphs
Add Graphs or Images to Hover Labels
Add Text to Hover Labels in JMP Graphs
Update Names and Values in Hover Labels
Edit Hover Labels in JMP Graphs
Add Images from JMP Data Tables to Hover Labels
Pin Hover Labels in JMP Graphs
Right-Click Options for Hover Labels
Customize Common Orderings
Load Common Orderings from a Data Table
Edit Common Orderings
Edit Items
Group Platform
Group Platform Options
Save Platform Preferences
Semantic Formatting
Format a Row in a Report Table
Format a Column in a Report Table
