DRAFT help
Consumer Research > Categorical Response Analysis
Publication date: 01/13/2026
Analyze Survey and Other Counting Data
The Categorical platform enables you to tabulate, chart, and compare categorical response data, including multiple response data. You can analyze data from surveys and other categorical response data, such as defect records and study participant demographics. The platform supports many data types and formats.
Figure 3.1 Categorical Analysis Example
Contents
Example of the Categorical Platform
Launch the Categorical Platform
Response Roles
Column Roles
Other Launch Window Options
The Categorical Report
Categorical Platform Options
Report Options
Statistical Testing Options
Additional Categorical Platform Options
Crosstab Table Options
Categorical Comparison Letters
Supercategories
Supercategories Options
Additional Examples of the Categorical Platform
Example of the Test for Response Homogeneity
Example of the Multiple Response Test
Example of Supercategories
Example of the Cell Chisq Test
Example of Compare Each Sample with Comparison Letters
Example of Compare Each Cell with Comparison Letters
Example of User-Specified Comparison with Comparison Letters
Example of Aligned Responses
Example of Conditional Association and Relative Risk
Example of Rater Agreement
Example of Repeated Measures
Example of Multiple Responses
Example of Mean Score with Comparison Letters
Example of a Structured Report
Example of a Multiple Response with Nonresponse
Set Preferences
Statistical Details for the Categorical Platform
Rao-Scott Correction
Rate Confidence Intervals
