DRAFT help
Publication date: 01/13/2026
Image shown hereCausal Treatment Report Options
The Fit Causal Treatment red triangle menu contains the following options:
Show Tips and Interpretations
Shows or hides the Analysis Findings section at the top of each Model report. This option also shows or hides additional instructional commentary throughout the Analysis of Causal Effects, Distributions, and Causal Assumptions Check sections.
For more information about the following options, see “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP:
Redo
Platform Preferences
Save Script
Note: Additional options for this platform are available through scripting. Select Help > Scripting Index. In the Scripting Index, you can also find examples for scripting the options that are described in this section.
