DRAFT help
Fitting Linear Models > Loglinear Variance Models > Loglinear Variance Fit Report Options
Publication date: 01/13/2026
The Loglinear Variance Fit red triangle menu contains the following options:
Save Columns
Contains the following options to save columns to the data table.
Prediction Formula
Saves a new formula column to the data table. The new column contains the predicted values for the mean, as computed by the specified model.
Variance Formula
Saves a new formula column to the data table. The new column contains the predicted values for the variance, as computed by the specified model.
Std Dev Formula
Saves a new formula column to the data table. The new column contains the predicted values for the standard deviation, as computed by the specified model.
Residuals
Saves a new column to the data table. The new column contains the residuals, which are the observed response values minus predicted values. See Example of Examining the Residuals in a Loglinear Variance Model.
Studentized Residuals
Saves a new column to the data table. The new column values are the residuals divided by their standard error.
Std Error of Predicted
Saves a new column to the data table. The new column contains the standard errors of the predicted values.
Std Error of Individual
Saves a new column to the data table. The new column contains the standard errors of the individual predicted values.
Mean Confidence Interval
Saves new columns to the data table. The new columns contain the bounds for a confidence interval for the prediction mean.
Indiv Confidence Interval
Saves new columns to the data table. The new columns contain confidence limits for individual response values.
Row Diagnostics
Provides various plots to help assess how well the current model fits.
Plot Actual by Predicted
Shows or hides a diagnostic plot with the actual values on the vertical axis and predicted values on the horizontal axis. This is the leverage plot for the whole model.
Plot Studentized Residual by Predicted
Shows or hides a diagnostic plot with the Studentized residuals on the vertical axis and the predicted values on the horizontal axis.
Plot Studentized Residual by Row
Shows or hides a diagnostic plot with the Studentized residuals on the vertical axis and the row number on the horizontal axis.
Profilers
Provides various profilers that enable you to explore the fitted model.
Profiler
Shows or hides the Prediction Profiler, which is used to graphically explore the prediction equation by slicing it one factor at a time. The prediction profiler contains features for optimization. For more information about the prediction profiler, see “Profiler” in Profilers.
Contour Profiler
Shows or hides the contour profiler, which shows the contours of the response graphically for two factors at a time. For more information about the contour profiler, see “Contour Profiler” in Profilers.
Surface Profiler
Shows or hides interactive surface plots for the response and the response standard deviation. For more information about the surface profiler, see “Surface Plot” in Profilers.
Model Dialog
Shows the completed Fit Model launch window for the current analysis.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
