DRAFT help
Using JMP > Set JMP Column Properties > Column Properties in JMP > Properties Used in Modeling and DOE
Publication date: 01/13/2026
When you construct a design by using the DOE platforms, column properties are saved to the resulting design table. However, some of these column properties are useful in general modeling situations. To use the properties more generally, you can specify them yourself.
Note: “Column Properties” in the Design of Experiments Guide describes the properties that are associated with DOE in detail and presents examples. Only a brief description of these properties is provided here.
The following column properties are used in modeling and DOE:
Response Limits
Detection Limits
Design Role
Coding
Mixture
Factor Changes
Response Limits
The Response Limits column property defines a desirability function for the response. The Prediction and Contour Profilers use desirability functions to find optimal settings. See “Response Limits” in the Design of Experiments Guide.
Image shown hereDetection Limits
The Detection Limits column property defines bounds beyond which the response cannot be measured. You can use these limits to specify a censored response in either the Distribution or Generalized Regression platform. See “Censoring” in Fitting Linear Models.
Design Role
The Design Role column property indicates how a column is used in both a designed experiment and in the model that is used to fit the data. For example, a column could represent a continuous factor, a categorical factor, a blocking factor, and so on. See “Design Role” in the Design of Experiments Guide.
Coding
The Coding column property applies a linear transformation to the data in a numeric column. The data are transformed to –1 and +1 based on bounds that you specify. JMP then uses the transformed data values whenever the column is entered as a model effect in the Fit Model platform. See “Coding” in the Design of Experiments Guide.
Mixture
The Mixture column property is useful when a column in a data table represents a component of a mixture. The components of a mixture are constrained to sum to a constant. The Mixture column property identifies a column as a mixture component and defines a coding for that column. See “Mixture” in the Design of Experiments Guide.
Factor Changes
The Factor Changes column property indicates how difficult it is to change factor settings in a designed experiment. It is used to create and analyze split-plot, split-split-plot, and two-way split-plot designs. See “Factor Changes” in the Design of Experiments Guide.
