Scripting Guide > Common Tasks
발행일 : 03/10/2025
Common Tasks
Getting Started with Sample Scripts
Examining working scripts line-by-line is one of the best ways to learn JSL. This chapter describes common tasks in JMP, such as converting date/time values and extracting specific values from reports. Sample scripts that address these issues are installed with JMP in the Samples/Scripts folder so you can run them yourself.
Contents
Run a Script at Start Up
Convert Character Dates to Numeric Dates
Format Date-Time Values and Subset Data
Create a Formula Column
Extract Values from an Analysis into a Report
Create an Interactive Program
