发布日期: 03/04/2025
Examples of HTTP Requests
The following examples communicate with the National Aeronautics and Space Administration (NASA) API. You must request a key from https://api.nasa.gov/index.html#apply-for-an-api-key and assign it to the key variable to run the scripts successfully.
Write Data to the Log
url = "http://technology.nasa.gov/api/query/patent/all";
request = New HTTP Request( URL( url ), Method( "Get" ) );
data = request << Send();
Write( data );
{"results":[["59fa04859600022b4d2e076f","LAR-TOPS-48","All-Organic Electroactive Device","NASA's Langley Research Center offers you an all-organic electroactive device system fabricated with single-wall carbon nanotube (SWCNT)....}
// JSON output written to the log
Notes:
• The query string is at the end of the URL, following “?”. For example, in https://www.google.com/search?q=jmp, “q=jmp” is the query string. New HTTP Request() automatically URI-encodes key/value pairs in a query string (and FORM).
• When you put an associative array in either a query string or a form, the key/value pairs get URI encoded. Spaces, ampersands, and other characters get encoded to ASCII, and the ampersand is escaped. The encoding is a “%” encoding.
• The web service defines the valid key/value pairs that it accepts. Refer to the API documentation for valid key/value pairs.
• For Kerberos authentication, specify the password as follows:
Password(":")
Return Data as an Associative Array and Write it to the Log
json = request << Send();
jsl_json = Parse JSON( json );
// turns JSON data into a JSL associative array
results = jsl_json["results"];
Write( results );
{{"59fa04859600022b4d2e076f", "LAR-TOPS-48", "All-Organic Electroactive Device", "NASA's Langley Research Center offers you an all-organic electroactive device system fabricated with single-wall carbon nanotube (SWCNT)....}}
// associative array
Return Data as a JMP Data Table
json = As JSON Expr( jsl_json["results"] );
dt = JSON To Data Table(
	json,
	JSON Settings(
		Stack( 0 ),
		Col(
			"/root",
			Column Name( "root" ),
			Fill( "Use Once" ),
			Type( "Pandas Values" ),
			Format( {"Best"} ),
			Modeling Type( "Continuous" )
dt << Set Name( "NASA Patents" );
Figure 14.5 Data Imported in a Data Table
此处显示图片
Disable Certificate Revocation Checks for SSL Backends
When you use curl with Windows SSPI, curl sometimes considers certificates to be revoked.
The Verify SSL(1) message sets the CURLSSLOPT_NO_REVOKE option in a CA bundle when the message is sent to a New HTTP Request() object.
Names Default To Here( 1 );
    Url( "https://developer.mozilla.org/en-US/docs/Web/HTTP/Conditional_requests/cache1.png" ),
    Method( "GET" ),
    Verify SSL( 1 )
bytes = request << Send;
img = Open( bytes, jpg );
obj = New Window( "Mastering JMP", img );
