Scripting Guide > Extending JMP
发布日期: 03/04/2025
Extending JMP
External Data Sources, Analytical Tools, and Automation
This chapter discusses scripting features that are particularly useful for production settings, such as the following:
• a data feed for capturing real-time data from a laboratory instrument
• using SAS, MATLAB, or R through JMP Scripting Language (JSL)
• using JMP with Microsoft Excel
• connecting to databases
• controlling JMP externally by OLE automation
• parsing XML
• publishing to JMP Public or JMP Live
• communicating with REST web services
• communicating with web APIs
Some general JSL commands that might be of particular interest for use in a production setting include Caption, Speak, Print, Write, and Mail. These functions are described in Functions that Communicate with Users.
Contents
Real-Time Data Capture on Windows
Create a Data Feed Object
Read in Real-Time Data
Manage a Data Feed with Messages
Examples of Data Feed Scripts
Dynamic Link Libraries (DLLs)
Use Sockets in JSL
Socket-Related Commands
Messages for Sockets
Database Access
Run Query Builder Queries
Open Database Function
Create a Database Connection and Execute SQL
Write a SQL Query
Work with SAS
Make a SAS DATA Step
Create SAS DATA Step Code for Formula Columns
SAS Variable Names
Work with MATLAB
Install MATLAB
Work with R
Install R
JMP to R Interfaces
R JSL Scriptable Object Interfaces
Conversion Between JMP Data Types and R Data Types
Troubleshoot Working with R
R Examples
Work with Microsoft Excel
Parse XML
OLE Automation
Share Content on JMP Live
JMP Live Prerequisites
Publish Reports or Data to JMP Live
Replace a JMP Live Report
Update Data in JMP Live
Communicate with REST Web Service
Examples of HTTP Requests
OAuth 2.0 for Web APIs
OAuth Security
Postman for Redirect URLs
Authorization Code Grant
Implicit Grant
Resource Owner Grant
Specify a Token
OAuth 2.0 Resources
Communicate with SAS Cloud Analytic Services
About CAS Actions
Connect to the CAS Server
Create and Submit a CAS Action
Create and Submit a CAS DATA Step Action
Create a New CAS Server
Import Data from the CAS Server
View a CAS Dataset
Get a List of Available CAS Libraries
Export Data from a Data Table to a CAS Server
Convert a CAS Table to a Data Table
Delete a CAS Table
Remove a CAS Table
Verify the CAS Server Connection
Get Details about the Current Connection
Disconnect from the CAS Server
Terminate All CAS Sessions
