Scripting Guide > Types of Data > Format Currency
发布日期: 03/04/2025
Format Currency
JMP displays numbers as currency using the Format() function, which uses the following syntax:
Format(x,"Currency", <"currency code">, <decimal>, < << Use Locale(Boolean));
Where:
• x is a column or a number
• "currency code" is an International Standards Organization (ISO) 4217 code
• decimal is the number of decimal places
To illustrate the Format function:
Format( 12345.6, "Currency", "GBP", 3 );
"£12,345.600"
By default, the operating system locale is used for the currency if the currency code symbol is omitted. For example, running the following script in a Japanese operating system formats the number with the yen symbol.
Format( 12345.6, "Currency", 3);
"¥12,345.600"
To ignore the computer’s locale and use a period for the decimal separator, include the Use Locale(0) argument:
Format( 12345.6, "Currency", 3, <<Use Locale( 0 ) );
Tip: If you change the region when JMP is open, restart JMP for the Use Locale setting to work properly.
If the currency code is not supported by JMP, the currency code string appears before the number.
Format( 12345.6, "Currency", "BBD", 3 );
"BBD 12,345.600"
Table 6.6 lists the currencies supported in JMP.
Table 6.6 Currencies Supported in JMP
Code
Currency
Code
Currency
Code
Currency
AUD
Australian dollar
ILS
Israeli new shekel
RUB
Russian ruble
BRL
Brazilian real
INR
Indian rupee
SEK
Swedish krone
CAD
Canadian dollar
JPY
Japanese yen
SGD
Singapore dollar
CHF
Swiss franc
KRW
South Korean won
THB
Thai baht
CNY
Chinese yuan
MXN
Mexican peso
TRY
New Turkish lira
COP
Colombian peso
MYR
Malaysian ringgit
TWD
New Taiwan dollar
DKK
Danish krone
NOK
Norwegian krone
USD
US dollar
EUR
Euro
NZD
New Zealand dollar
ZAR
South African rand
GBP
British pound
PHP
Philippine peso
HKD
Hong Kong dollar
PLN
Polish zloty
For more information about how to format currency, see Format Numbers.
