Click the selected items and drag them from JMP to the other program. Or, copy the selected items in JMP and paste them into the other program. When you paste an element into another application, the format used depends on the application into which you paste. If the application has a Paste Special command and you use it, you can select a format to use, such as text (.rtf), unformatted text (.txt), bitmap (.bmp), or Enhanced Metafile (.emf).
To copy all text (no graphs) from the active report window as unformatted text, select Edit > Copy As Text. On the Macintosh, select Edit > Copy As Text.
To copy anything other than a graph, right-click and select Edit > Copy Picture. For example, to copy a report, right-click on the bar containing the report title and select the option.
