Web Browser (Safari, IE, Firefox, Chrome, Other)
Operating System (Windows or Macintosh)
RAM (4, 8, or 16 MB)
Connection Speed at three settings (0-1, 1-5, or greater than 5 Mbps)
The Software Factors.jmp data table contains the factors and their settings.
Select DOE > Covering Array.
From the menu next to Strength: t = , select 3.
Click Continue.
6.
Click Make Design.
In the Metrics outline, consider the row that corresponds to t = 3. The Coverage is 100%, indicating that the design covers 100% of the three-factor interactions. This is what you want, because you requested a Strength 3 design. For t = 3, the Diversity column indicates that 68.33% of the three-factor interactions that appear are distinct. There is some minor repetition of three-factor combinations.
For t = 4, the Coverage is 50%, indicating that the design covers half of the four-factor interactions. There are 90 possible distinct combinations of the four factor settings. The 45 runs in the design comprise one-half of these distinct combinations. The Diversity value of 100% reinforces the fact that none of the four-way interactions are repeated.
7.
Click Make Table.
Now that you have your design table, you can conduct your experiment and record your data in the Response column of the design table (Design Table for Software Factors). Your experimental results are in the Software Data.jmp sample data table.
Two failures were associated with Web Browser set to Firefox, Operating System set to Macintosh, and RAM set to 8 MB. Notice that this combination led to failure regardless of the setting of Connection Speed.
Three failures were associated with combinations of Web Browser, RAM, and Connection Speed. Note that two of these failures, Firefox, 8 MB, 1-5 Mbps and Firefox, 8 MB, >5 Mbps, are among the two failures for the Web Browser, Operating System, and RAM interaction. Selecting any of these rows in the report selects the corresponding rows and columns in the data table.
