JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Profilers
• Mixture Profiler
Mixture Profiler
Explore Factor Effects using Ternary Plots
The Mixture Profiler shows response contours for mixture experiment models, where three or more factors in the experiment are components (ingredients) in a mixture. The Mixture Profiler is useful for visualizing and optimizing response surfaces resulting from mixture experiments.
Mixture Profiler Example
Contents
Mixture Profiler Overview
Explanation of Ternary Plot Axes
Mixture Profiler Platform Options
Customizing the Mixture Profiler
Linear Constraints
Examples
Single Response
Multiple Responses
