You can view or hide each option (Frequencies, Share of Responses, Rate Per Case, Share Chart, Frequency Chart, or Transposed Freq Chart) from the Categorical red triangle menu. Data from Consumer Preferences.jmp is displayed in The Categorical Report.
For example, examine the second row of the table for Floss After Waking Up. The 37 responses who floss when they wake up were 25.9% of all responses (37/143*100).
For example, in the third row of the table (Floss After Waking Up), the 37 respondents are from 113 cases, making the rate per respondent 32.7%.
The Frequency Chart shows response frequencies. The bars reflect the frequency count on the same scale and the number of responses are displayed to the right. To view the frequency chart, select Frequency Chart from the Categorical red triangle menu.
