Customer Story
Data scientists build efficiency into electric utility construction
Valard Construction uses dynamic JMP® tools to optimize the productivity of construction crews
Valard Construction
Valard Construction
ChallengeOptimize personnel to reduce the labor costs that, for large-scale electric utility construction projects, could account for up to half the final budget.
SolutionUse data models in JMP to identify areas for improvement after systematically tracking and evaluating construction crew productivity; roll out optimizations to other parts of the company.
ResultsThe data science team is helping to reduce overall labor costs and project time with its data-driven labor force optimization strategy; the team continues to develop models addressing other challenges across a range of construction projects.
In the electric utility construction industry, few companies rival the size and expertise of Edmonton-based Valard Construction. Now with over 3,000 employees, Valard has designed and executed large-scale transmission power line projects for customers across Canada since 1978, providing a full-service engineering, procurement and construction solution while maintaining rigorous safety and quality standards. The bulk of their employees work in the field, as these projects are highly labor-intensive; a typical large-scale transmission project involves several hundred towers and can cost over $1 billion. With such large budgets, even the smallest change in productivity can have a large impact on project costs and timelines; as such, effective labor management is key to success in this industry.
Valard logo
Investigating new avenues for optimization
Traditionally, the construction industry has relied heavily on project managers and foremen to determine necessary staffing levels and ideal work conditions. While the on-the-ground knowledge of these veteran staff is an invaluable resource, the steep costs of labor invite a closer, more analytical approach to project planning and cost management.
Recognizing the value of analytics, Valard has made a strong investment in its data science operation. Serguei Roupassov brings a background in computational physics to his team of data scientists that support a variety of analytics initiatives at the company, from financial forecasting to substantiating analytics for construction claims. He also makes time for his own initiatives – recently, this has included waste reduction and productivity analyses. It is here, in the productivity analyses, that Roupassov sees an important opportunity for transforming Valard’s approach to labor management and forecasting, allowing Valard to make the most out its workforce and reduce project costs. “Labor could easily be half the cost of the actual product,” Roupassov asserts. “That’s why optimizing things like labor productivity gives immediate return.”
Given the impact of labor on construction budgets, optimizing productivity by even a small margin can significantly affect timelines and costs. However, measuring productivity can be a complex task. “You have crews that work on the tower, then the next day another crew comes,” says Roupassov. “It’s very hard to actually quantify what each particular individual has achieved during a workday. You know they’ve spent eight or 10 hours, but how much actually has been produced?” In his effort to quantify productivity more accurately, he has evaluated various operational and accounting data from all over the company, including timesheets, GPS location data and types of activities performed.
Still, measuring productivity is only part of the puzzle. To effectively model and forecast worker productivity, it’s also necessary to understand the magnitude to which various factors affect productivity, such as:
  • Crew size
  • Crew composition
  • Seniority
  • Experience
  • Foreman
  • Season
Investigating all potential parameters takes time and a creative approach to data analysis. “We can look at the observational data for a long time,” he says, “but it doesn’t fill the parameter space.”
Power lines
Developing effective labor force models with JMP®
The complex intersection of data and personnel necessitates a robust tool that can support Roupassov throughout the model development process. To start, collecting various operational data from across the company can be tedious. “We have the data in the data warehouse and several databases,” Roupassov says. “JMP is good because it allows you to easily connect to various data sources and integrate and clean data, that’s a big thing.” With other responsibilities competing for the time of his small team, these functionalities enable Roupassov to focus his attention on more challenging aspects of modeling the data.
“Crew identification and tracking is kind of cumbersome to deal with,” says Roupassov. “The main point is, crews do not stay constant – they change all the time.” Finding a way to effectively model crews that are constantly in flux poses a challenge, but one that he has been able to overcome with a combination of tools like JMP clustering and his own code developed for this project. Conducting such an analysis of crews on a recent project, Roupassov was able to categorize 96 distinct crews and subsequently analyze crew productivity as they assembled towers on a given project, allowing him to better understand the factors that affect their productivity.
Valard construction workers
“JMP is good because it allows you to easily connect to various data sources and integrate and clean data. That’s a big thing.” – Serguei Roupassov, Data Scientist
“The interactive visualization part ... I love it”
To Roupassov, the visual representation in JMP is another key differentiator that elevates it above other products. “Other analytics tools can be very powerful, but data visualization is typically static … Interactive visualization in JMP helps you understand and explore the data at a totally different level.”
These capabilities allow the team to effectively communicate their findings with staff across the company in a clear, dynamic way, from project managers all the way up to the executive level; this ease of communication is particularly important as the team seeks to build a set of practices that will help the company to maintain a competitive edge.
“In my industry, the models that I build have to be explainable,” Roupassov explains. “Neural networks, for example, I can’t use in many cases. Maybe a neural network model would predict better, but it’s not easily explainable. How would I communicate the reasons why I’m making these conclusions if I can’t explain how the model works?” With the interactive, easy-to-understand visualization capabilities of JMP, the data science team can clearly convey their findings to key decision makers.
Bringing a new approach to an old-school industry
Roupassov is using the various tools that JMP offers to create a model that will soon be deployed to optimize productivity on many of Valard’s projects. By tracking crew productivity and clearly understanding the key variables, project managers will be able to objectively evaluate optimize crew performance. “It would also help people to forecast if they see that the productivity, for example, is not as high as we expected. We can then adjust the forecast, maybe bring more crews in to stay on schedule,” he says.
Using statistics in this way pushes against the conventional wisdom typically relied upon in construction. Many of the upper-level managers now leading the industry don’t have a formal background in analytics or statistical modeling, but despite this being a new concept in the industry and the company, they have been very supportive of the analytics work being done. “JMP data visualization and interactivity has helped managers see the unexploited possibilities to make the business more efficient. And changing [former ways of thinking] is not easy.” But, Roupassov says, for companies who are willing to embrace the new data-rich environment, the rewards are well worth the risk. And a forward-thinking analytics strategy, like the one in place at Valard, can more than pay for itself.
By first engaging with project teams who are open to making decisions based on his models, Roupassov has implemented productivity improvements on a small scale that have then encouraged wider uptake throughout the company. In using this data-driven, dynamic approach to project management – and doing so before many others in the construction industry – Valard is a real pioneer.
The results illustrated in this article are specific to the particular situations, business models, data input and computing environments described herein. Each SAS customer’s experience is unique, based on business and technical variables, and all statements must be considered nontypical. Actual savings, results and performance characteristics will vary depending on individual customer configurations and conditions. SAS does not guarantee or represent that every customer will achieve similar results. The only warranties for SAS products and services are those that are set forth in the express warranty statements in the written agreement for such products and services. Nothing herein should be construed as constituting an additional warranty. Customers have shared their successes with SAS as part of an agreed-upon contractual exchange or project success summarization following a successful implementation of SAS software.
Back to Top
