Publication date: 01/13/2026
Image shown hereModel Reports
When you click Run in the Causal Treatment Fit Model launch window or click Go in the Fit Causal Treatment report Model Launch control panel, JMP produces a Model report. When you select the Show Tips and Interpretations option from the Fit Causal Treatment red triangle menu, the Model report contains the following sections:
• Analysis Findings
• Model Information
• Analysis of Causal Effects
• Distributions
• Causal Assumptions Check
• Model Fit Details
• Propensity Score Matching Summary
Note: The contents of these sections change depending on the type of the treatment. These differences are described in each section page. The Propensity Score Matching Summary appears only when the treatment is binary and the Propensity Score Matching Method is set to Nearest Neighbors.
If propensity score matching is used, the Model report contains an additional section. See Propensity Score Matching Summary.
The Model report red triangle menu contains the following options:
Save Causal Results Columns
Saves new columns to the original data table. The new columns contain the propensity score, weight, and potential outcome estimates.
Remove Fit
Removes the current Model report from the Fit Causal Treatment report.
