Fitting Linear Models > Causal Treatment Models
Publication date: 01/13/2026
Image shown hereCausal Treatment Models
Estimate Causal Effects Using Observational Data
The Causal Treatment personality of the Fit Model platform is available only in JMP Pro.
The Causal Treatment personality enables you to estimate causal effects by using observational data. Causal questions are most directly answered by analyzing experimental data that are collected from randomized controlled trials. However, researchers often cannot randomly assign observations to receive a certain intervention because of ethical concerns or logistic constraints.
The Causal Treatment personality estimates the average treatment effect by leveraging insights from models that describe the treatment (X) and outcome (Y) mechanisms to mitigate confounding bias. These models enable you to answer the following questions:
• Does X cause Y?
• How would changing X affect Y?
• What would be the expected value of Y if no observations had received the treatment (X = 0), or if every observation had (X = 1)?
You can use the Causal Treatment personality to analyze the effects of binary or continuous treatments on binary or continuous outcomes. The personality also provides visualizations to help assess causal assumptions.
Figure 14.1 Propensity Score Density Plot for Evaluating the Positivity Assumption
Contents
Overview of the Causal Treatment Personality
Example of a Causal Treatment Model
Launch the Causal Treatment Personality
Response Model Tab
Treatment Model Tab
Causal Treatment Report Window
Causal Treatment Report Options
Model Launch Control Panel
IPW Extreme Weight Truncation Threshold
Stabilized Weights
Advanced Models
Model Reports
Analysis Findings
Model Information
Analysis of Causal Effects
Distributions
Causal Assumptions Check
Model Fit Details
Propensity Score Matching Summary
Additional Examples of the Causal Treatment Personality
Example of a Continuous Treatment
Example of Propensity Score Matching
Statistical Details for the Causal Treatment Personality
Statistical Details for Causal Assumptions
Statistical Details for Causal Estimands and Estimators
Statistical Details for Continuous Treatment Methods
Statistical Details for Missing Values in the Outcome
