Definitive Screening Design Flow
Responses Outline
Tip: When you have completed your Responses panel, consider selecting Save Responses from the red triangle menu. This saves the response names, goals, limits, and importance values in a data table that you can later reload.
The name of the response. When added, a response is given a default name of Y, Y2, and so on. To change this name, double-click it and enter the desired name.
Factors Outline
The name of the factor. When added, a factor is given a default name of X1, X2, and so on. To change this name, double-click it and enter the desired name.
Note: Use the Add Blocks without Extra Center Runs option only if you can assume that not all quadratic effects are important.
If a design contains a categorical factor, a center run is a run where all continuous factors are set at their middle values. If all factors are categorical, the two blocking options are available. Both options produce designs whose blocks are orthogonal to main effects.
The Add Blocks with Center Runs to Estimate Quadratic Effects option constructs a design with these properties:
If a design contains only continuous factors, a blocked design for k factors having these properties can be constructed as follows:
When some factors are categorical, the Add Blocks with Center Runs to Estimate Quadratic Effects option adds pairs of center runs within certain blocks. This structure ensures orthogonality and the ability to estimate all main and quadratic effects.
The Add Blocks without Extra Center Runs option constructs a design that has a single center run when all factors are continuous and two center runs when some factors are categorical. The resulting design has these properties:
A blocked design for k factors without extra center runs is constructed as follows:
Output Options Panel
The Run Order options determine the order of the runs in the design table. Choices include the following:
Click Make Table to construct the Definitive Screening Design data table.
Runs the Analyze > Modeling > Screening platform.
Runs the Analyze > Fit Model platform. The model described by the script contains the main effects for the factors that you specified. If you requested a block, the model includes the factor Block.
Definitive Screening Design Table Showing Scripts
