Design of Experiments Guide > Sample Size Explorers > Power Explorers for Hypothesis Tests
Publication date: 01/13/2026
Use the power explorers to calculate the sample size for hypothesis tests. Explore the impact of sample size on the power of a hypothesis test to detect a specified difference. The difference could be from a constant (one-sample case) or between two groups (two-sample case). For the one-sample case, the hypothesis is about the single parameter (mean, proportion, variance, or counts per unit). For the two-sample case, the hypothesis is about comparing two groups. For more than two groups, you can use the Power Explorer for ANOVA, see Power for ANOVA.
For hypothesis testing, select DOE > Sample Size Explorers > Power:
• Power for One Sample Mean
• Power for One Sample Proportion
• Power for One Sample Variance
• Power for One Sample Equivalence of Means
• Power for One Sample Counts Per Unit
• Power for Two Independent Sample Means
• Power for Two Independent Sample Proportions
• Power for Two Independent Sample Variances
• Power for Two Independent Sample Equivalence of Means
• Power for Two Independent Sample Counts Per Unit
• Power for Two Correlated Sample Means
• Power for ANOVA
