Design of Experiments Guide > Sample Size Explorers
Publication date: 01/13/2026
Sample Size and Power Calculators
When planning experiments or studies, use the Sample Size Explorers to explore trades offs between the number of items tested and the estimated strength of the study. Use the explorers to answer the following types of questions:
• How many units should I test?
• Are the differences in treatment means detectable?
• How many samples are needed to construct an interval with a specified width?
• How many units must I test to estimate failure time?
The Sample Size Explorers are a collection of interactive utilities that enable you to adjust study parameters and assumptions to explore different study designs. The tools are grouped by use:
• Power for hypothesis testing
• Confidence interval for interval estimation
• Reliability for reliability demonstrations and life testing
• Quality for sigma quality level
Figure 29.1 Sample Size Explorer for One Sample Mean
Contents
Overview of the Sample Size Explorers Platform
Example of Sample Size Explorers
Launch Sample Size Explorers
Power Explorers for Hypothesis Tests
Power for One Sample Mean
Power for One Sample Proportion
Power for One Sample Variance
Power for One Sample Equivalence of Means
Power for One Sample Counts Per Unit
Power for Two Independent Sample Means
Power for Two Independent Sample Proportions
Power for Two Independent Sample Variances
Power for Two Independent Sample Equivalence of Means
Power for Two Independent Sample Counts Per Unit
Power for Two Correlated Sample Means
Power for ANOVA
Confidence Interval Explorers
Confidence Interval for One Sample Mean
Confidence Interval for One Sample Proportion
Confidence Interval for One Sample Variance
Confidence Interval for One Sample Counts per Unit
Confidence Interval for Two Independent Sample Means
Confidence Interval for Two Independent Sample Proportions
Confidence Interval for Two Independent Sample Variances
Confidence Interval for Two Independent Counts per Unit
Reliability Explorers
Parametric Reliability Demonstration
Nonparametric Reliability Demonstration
Reliability Life Testing
Parametric Tolerance Intervals
Nonparametric Tolerance Intervals
Quality Explorers
Acceptance Single Sampling Plan
Sigma Quality Level
Remembered Settings in the Sample Size Explorers
