X-charts display subgroup means (averages)
R-charts display subgroup ranges (maximum – minimum)
S-charts display subgroup standard deviations
Levey-Jennings charts show a process mean with control limits based on a long-term sigma. The control limits are placed at 3s distance from the center line. The standard deviation, s, for the Levey-Jennings chart is calculated the same way standard deviation is in the Distribution platform.
Count
The CCB makes a few decisions for you based on the variable selected. For example, if there is no X variable, a c-chart is originally created because there is no way to estimate the binomial distributions. Upon adding an X variable (or lot size), the platform switches to a np-chart if the count per subgroup is less than the subgroup sample size. Once the basic chart is created, you can use the menus and other options to change the type, the statistic, and the format of the chart.
p-charts display the proportion of nonconforming (defective) items in subgroup samples, which can vary in size. Because each subgroup for a p-chart consists of Ni items, and an item is judged as either conforming or nonconforming, the maximum number of nonconforming items in a subgroup is Ni.
np-charts display the number of nonconforming (defective) items in subgroup samples. Because each subgroup for a np-chart consists of Ni items, and an item is judged as either conforming or nonconforming, the maximum number of nonconforming items in subgroup i is Ni.
