Enables you to create the principal components based on Correlations, Covariances, or Unscaled.
Correlations
Covariance Matrix
If you select the Bartlett Test option from the red triangle menu, hypothesis tests (Bartlett Test) are given for each eigenvalue (Jackson, 2003).
Eigenvalues
Eigenvectors
Bartlett Test
Loading Matrix
Biplot
Scree Plot
Scatterplot 3D Score Plot
The variables show as rays in the plot. These rays, called biplot rays, approximate the variables as a function of the principal components on the axes. If there are only two or three variables, the rays represent the variables exactly. The length of the ray corresponds to the eigenvalue or variance of the principal component.
Cluster Summary
