If you have a model with nominal or ordinal terms, when you click Make Model or Run Model, the Fit Model platform creates a new set of columns in the data table. The model appears in a new Fit Model window for the response variable. The next example uses the Hotdogs2 sample data to illustrate how Stepwise constructs a model with hierarchical effects.
A simple model examines at the cost per ounce ($/oz) of hot dogs as a function of the Type of hot dog (Meat, Beef, Poultry) and the Size of the hot dog (Jumbo, Regular, Hors d’oeuvre).
Open the Hot Dogs2.jmp sample data table.
Select Analyze > Fit Model.
Select $/oz and click Y.
Select Type and Size and click Add.
For Personality, select Stepwise.
6.
Click Run.
7.
For Stopping Rule, select P-value Threshold.
8.
For Rules, select Restrict.
9.
Current Estimates Report for a Model with Hierarchical Effects
10.
Click Make Model.
