Fitting Linear Models > Stepwise Regression Models
Publication date: 01/13/2026
Fit a Model Using Variable Selection
Image shown hereSome features in this platform are available only in JMP Pro and noted with this icon.
The Stepwise personality of the Fit Model platform enables you to use stepwise methods to fit regression models, explore all possible models for a set of regressors, and conduct model averaging.
Stepwise regression is an approach to selecting a subset of effects for a regression model. It can be useful in the following situations:
• There is little theory to guide the selection of terms for a model.
• You want to interactively explore which predictors seem to provide a good fit.
• You want to improve a model’s prediction performance by reducing the variance that is caused by estimating unnecessary terms.
For model selection, you can perform the following tasks:
• Choose from among various rules to determine how associated terms enter the model
• Enforce effect heredity
• Image shown hereUse cross validation criteria with respect to a holdout set
• Fit and rank all possible models for a set of regressors
• Conduct model averaging
Figure 5.1 Stepwise Report Window
Contents
Overview of Stepwise Regression
Example Using Stepwise Regression
Launch the Stepwise Personality
Validation Options in Stepwise Regression
Stepwise Fit Report
Stepwise Regression Control Panel
Current Estimates Report
Step History Report
Stepwise Fit Report Options
All Possible Models
Model Averaging
Additional Examples of the Stepwise Personality
Example of the Combine Rule
Example of a Model with a Nominal Term
Example of the Restrict Rule for Hierarchical Terms
Example of Logistic Stepwise Regression
Example of the All Possible Models Option
Example of the Model Averaging Option
Example of Forward Selection
Example of Backward Selection
Statistical Details for the Stepwise Personality
Models with Crossed, Interaction, or Polynomial Terms
Models with Nominal and Ordinal Effects
Construction of Hierarchical Terms
Logistic Stepwise Regression for Binary or Ordinal Responses
Validation Details
